FME2011 Use Case: Coordinate Swapping
Hi FME’ers,
Here’s a short and sweet post about a new transformer in FME2011: the CoordinateSwapper
The CoordinateSwapper transformer does as you’d imagine and swaps coordinates from one axis to another; for example X becomes Y and Y becomes X. I can see three potential uses for such a transformer.
Lat/Long Swapping
You’re probably aware of the controversy about coordinate order in spatial data; should it be lat-long (Y/X) or long-lat (X/Y)? I think it’s generally accepted that long-lat (X/Y) is the preferred option, but you might still find some datasets where this is reversed.
This is the reason why this transformer was created. It was intended as a way to allow users to quickly and easily switch their lat-long data to long-lat (or vice versa if they preferred).
Very simply you just place the transformer and specify an X Y swap….
…which will have this effect:
Easy!
Cross-Sections
The nice thing about this transformer is that it also includes the ability to swap the X or Y coordinate with the Z value. That way you can create cross-sections of data very easily.
Check out this workspace (click to enlarge):
The source data is a transit line that I would like a cross section of. The data prep consists of providing Z values by draping the transit line over a DEM. The only transformer of real interest there is the Scaler, where I am scaling the Z values to give a better display of elevation change in the output.
There are two CoordinateSwapper transformers. Firstly I swap X and Y, because the line runs North to South and I wish to see it run from Left to Right on the output.
Then I swap Y and Z to turn it into a cross-section. The output looks like this:
Not visually stunning, but not bad for a couple of minutes work. It clearly shows how the line increases in elevation – at a very much exaggerated scale – as it heads north out of the city. It wouldn’t be too much work to plot stations on there as well (I just don’t have that data).
I suppose if I had rider numbers I could attach them as a Z value (instead of elevation) and see where ridership spikes occur.
For another example, check out the CoordinateSwapper page on fmepedia, where I swap coordinates on a 3d model of the Gavle Goat to get a view in different perspectives:
No reason why you couldn’t do the same with a more realistic CAD or BIM 3D model!
Data QA
But what might be the most useful function of this transformer is as a tool for data QA.
For example, it’s very hard to tell from a 2D view if a feature is missing Z values or has a wildly incorrect Z value:
But with the CoordinateSwapper transformer, you can swap in the Z values for X or Y, and get a much clearer view of where there are problems:
As you can see, it’s a very powerful tool for locating spikes in Z values.
I hope this short post will be of use – and don’t forget to check out the What’s Great page on fmepedia for a full list of the new transformers in FME2011.
Cheers,
